Old 11-05-2006, 01:33 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
I have regularly bought cars and driven them the distance home right after purchase. I think that the first lookover and test drive will let you know whether you will feel comfortable with the return drive. Just don't try and break any records and be arrenrive ro anything that may change from when you take off. I say change because it will most likely make noises that are not what you are accustomed to in your daily driver, but it isn't neccesarily a problem. It may take a little time to adjust to some of the sounds, but as I said only be concerned if it changes on the trip. You might also post here when you plan to make the excursion and there may be some SPF/Cobra owners that will give you some contact info if you have problems in their area. What would be the route you take?
WDZ
