  #25 (permalink)
Old 11-06-2006, 03:38 PM
spookypt spookypt is offline
Default Wheels
Gents, I connot begin to tell you how hard it is to find suitable wheels.... You need a min of 34mm to miss the Nissan Brake calipers. Most wheels have the offset stamped inside them... But baiscally if you measure the rim depth front and rim depth rear it will tell you how much posi or nega offset you have. Get straight edge lay across rim face and measure into where wheels bolts up (inner face) then to the same on the outside edge. Basically if you have 300mm outer and 320mm inner then then you have a 10mm posi offset. (I think??) I have to go for a Japanese 3 piece wheels which is hard because in isnlt a Japancese car...Doh!
I might start a new thread and see what other have done?
SpookyPT
