Old 11-08-2006, 09:06 AM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Originally Posted by lineslinger
Do you know whether the galley plugs are threaded or pressed in? Pressed in plugs are notorious for leaking and the threaded plugs..., unless properly sealed upon installation will also "seep" once the motor has been warmed up and the oiling system pressurised with hot oil.
I have seen teflon tape used as a thread sealer and fail once things heat up and are pressurised.
I thought so.........glad you nailed it down, territorial marking by an engine drives me up the wall.
