Old 11-08-2006, 08:45 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Following the guide to measure correct height in a must as mentioned by Jet. See MSD's instructions here http://www.msdignition.com/pdf/gear_...d_frm22770.pdf
Many surfaces often altered during a rebuild affect this distance and even factory +/- to0lorances when stacked up present a problem if not corrected. Big cams or higher V spring presures also cause this to be an important spec. have fun, it is really pretty easy to do so not a big deal.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
