  #27 (permalink)
Old 11-09-2006, 03:06 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Good project Russell,
I'd like to see the rear suspension pickup points brought in a bit and some shorter axles used. I'm not keen on the tyres hanging out of the guards look.
I looked at using the vette transaxle and torque tube but it was too much work to change my chassis to accept it. It would have made maintenence a pain too. Your car will have a more rearward weight bias than most Cobras. Most seem to be near 50:50 or 52 rear 48 front. Th LS1 only weighs about 400 pounds so that will make for even more rearward bias. It should hook up well.
Bill,
The clutch on one of these engines is in the conventional position with the flywheel on the back of the motor.
In my opinion the torque tube setup is safer than a conventional gearbox setup. There's no universal joints just a straight shaft with greek couplings or similar between the engine and gearbox. This is all contained in a sturdy aluminium tube in case something does brake. That's unlikely though because there's no uni joints which are the weak link in a drive shaft. It's also a lot smoother because there's no vibration induced by uni joints changing angle. Therefore it's more efficient.
In a conventional car setup you are far more likely to have a driveshaft failure catastrophic results than a clutch explosion these days. There's no danger of this with a torque tube.
A scatter shield could be very easily incorporated into the tunnel around the bell housing negating the need for a big heavy steel bell housing. This could be done with a balistic blanket or just steel sheet welded into the tunnel area in the right spots. Clutch explosions are a rare thing these days anyway.
Clutch and flywheels have come a long way sinc the days of grey iron flywheels breaking apart at high RPM. Billet steel flywheels are essentially explosion proof and rated to huge RPM. I put an SFI approved billet steel flywheel in mine and it only weighs 15.5 pounds which is about the same as an aluminium flywheel.
Mike Murphy
Melbourne Australia
