Old 11-09-2006, 09:19 PM
Geary L. Sarno Geary L. Sarno is offline
Cobra Make, Engine: Unique 427SC, 403 FE. Dual Quad
Jon - Attached is an image of the dual Edelbrock setup on my personal car. It is a non-progressive straight-pull. The engine is a 403 FE(390 +.060) and the carbs are a pair of 1405's (600 cfm). The car is an outstanding performer.
The tech at Edelbrock is correct. Mirror the carbs. When you are off the idle curcuit and on the main jets the fuel flows proportional to the air flow. It doesn't matter if you are flowing more air through one of the carbs as in a progressive setup. Each carb will feed fuel according to the volume of air passing through it.
I have built two other cars for resale. The first was a 302, Edelbrock f-28 manifold, twin 1405's and progressive linkage. The second was a 289, high rise intake(from Branda), twin 1405's, and non-progressive linkage. In each case the carbs were jetted to their engine's fuel requirements, but all carb pairs were mirrored. Once you match the fuel/air requirements of your engine you can feed it with one carb opened 1/4 inch or two carbs opened 1/8 of an inch. The progressive linkage never really impressed me. As you may have noticed, I do like the twin carb setups. While you may lose a bit of volumetric efficiency with the twin setup, You can't beat it for looks and bragging rights. You've got a gut wrenching 428 in a very lightweight vehicle. Getting 2 more mpg cruising around town on progressive two barrels just isn't an issue. Cruise around on four primaries at 1/2 the throttle opening.
Keep in touch with Edelbrock support, start adjusting with the jetting on the rich side, and you can get the jets/rods close with a good ear and "seat of the pants" feel. Fine tune it on the dyno after your up and running. Study the carb manual. The carbs are relatively simple.
- Geary
