Old 11-10-2006, 08:54 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by scottj
Too large of a cfm rating, i.e. "over-carbing", will result in a small gain in top end at the expense of poor low speed throttle response- refering to engine speed. Over-carbing doesn't mean that the engine will run rich; it just means that overall drivability will be compromised. Rich/lean is a calibration issue. A carb of anysize, if improperly calibrated for the engine, could cause a rich (or lean) condition. A common mistake made is to install a large carb, calibrated for a racing engine, on a street/performance engine. A race-calibrated carb will run too rich at idle and low engine speeds on a mildly cammed engine.
Scott
Assactly correct. You could wash the cylinders with a 600 cfm if it is not jetted properly.
Replica is not a dirty word.
