Old 11-12-2006, 10:29 AM
Rick Parker's Avatar
In the tubular "A" arms that I have the Large outer surface of the Ball Joints are threaded and screw into the "A" arm. To visually check the fit, the shoulder of the Ball joint should be threaded down tight against the upper threaded boss. Are you sure the looseness is there? Can you visually see it? I myself have some minor amount of looseness that can be felt but it is the wheel bearings and will soon be corrected. The loosness could also be at the pivot points of the upper arm where it attaches to the chassis.
Rick
