Old 11-14-2006, 12:34 PM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
You said that the first ring gear was missing teeth and the gear on the starter was all chewed up. Unless you are really unlucky, this should not happen. Typically a ring gear and a starter will last for a very long time.
Now the new starter will not remain engaged with for more than a couple of seconds. This sounds to me that there is some sort of a basic alignment problem. I seem to remember that Ford has several differnt flywheels. I also have a Lakewood bellhousing and I did quite a bit of research before buying my flywheel and clutch / pressure plate assembly. I have looked through my receipts but I cannot find the one for the flywheel. Is it possible that the flywheel is not the correct diameter for that bellhousing/starter combination?
Wayne
Don't get caught dead, sitting on your seat belt.
