Old 11-14-2006, 11:02 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
SFM5S159, first of all, I'm not sure what size the Bj/BK carbs are, but I believe they're a bit smaller than 600 cfm; could be wrong, but 535 cfm comes to mind. Doesn't matter, vacuum secondaries only open when the engine can use the extra fuel/air, and only open as much as the engine can use; so even if they're rated at 600 cfm, they won't supply that much cfm on your engine. Run those puppies!
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
