  #21 (permalink)
Old 11-18-2006, 11:16 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Carnut427
BTW, I also found that one 90* bend creates as much resistance as 8' of straight pipe. We were having problems getting enough oil flow in some machinery, causing premature bearing failures.
Whan I plumbed my car, I tried to use the radiused fittings on all fuel and oil ends, trying to avoid 90 elbow bends. I couldn't do so on the outflow of the mechanical fuel pump, so it has a 90 elbow, as well as the oil return line back at the block.
There's a 90 elbow inside the remote oil filter mount itself, the center outflow, although I took it apart, and tried to chamfer the corner, trying to make it into two 45 degree bends, but if I remember correctly, I think it was already like two 45 degree bends instead of a single 90.
With 90 elbows, I had thought about putting a little epoxy in the long radius, corner, of a 90 elbow fitting, again to try to make it into two 45 bends instead of a single 90 to try and smooth out the flow. I actually think I did this in the 90 elbow outflow from the mechanical fuel pump, but I can't remember for sure, as I'd have to take the fitting off to reinspect it. I know I didn't do it on the oil return elbow to the engine block. It would really have to tested to see if it really makes any difference, but again, I do think I put some epoxy inside the elbow fitting on my fuel system, like this.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
