  #1949 (permalink)
Old 11-20-2006, 03:51 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
I couldn't get on the site at all yesterday morning as all I got was the server is down message. Didn't try yesterday afternoon.
Brent,
If you have checked all connections and everything is good then it could be the unit. I have never had one fail, but they are like everything and can go bad. Are you running the Pro Street? You can just wire around the unit itself and run off the distributor and the coil like a regular ignition and they will tell you if the unit is bad. I had a similar situation once years ago and one of the connectors in my trigger wire was not good even though it tested good with an ohm meter. Are you using a points distributor or a magnetic pick up one? The Jacobs will not work long with the optical type and tells you in the papers to not use them. Hope this helps.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
