[b]
Horn no power at # 11 contacts, I have 12V at horn relay #30 & #85, 0V at #86 & #87. Checked connections at #48 and #49 and they seem OK. Any thoughts?
Ground the pink wire from the horn relay using a sharp probe into the relay socket. Does the relay click?
Fanno power at #44 and no power at #16 contacts, Fan relay has 12V at #30 & # 85 and 0V at #86 and # 87. Her again- any thoughts ?
If there's power to #44 orange and #44 black wire is grounded, the fan should work. We've only had one bad fan over the years, but that's a possibility.
I have 12V on all passenger side fuse panel terminals and 12V on the top terminal ONLY on the driver's side fuse panel.
That's as it should be.
