Old 11-26-2006, 06:58 AM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
As others have said, check your initial timing, try 10º to 12º BTDC, and lower the fuel pressure to around 6 or 7 PSI. If you have 0 oil pressure aty idle, shut it off immediately! The oil pump driveshaft may have pulled out of the oil pump.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
