Old 11-26-2006, 09:04 PM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
X, yes, the pickup must have proper clearance between it and the pan. This does happen now and then and is not uncommon. Without proper clearance, you won't get pressure,(or only a little). It's good that your drill is bogging down during the priming process. It's hard work for a drill to turn an oil pump, it will burn up a cheap drill in a heartbeat.
good luck,
Tim
" It ain't no big deal"
