Old 11-29-2006, 08:12 AM
keislerNick keislerNick is offline
Yes there are other places the trans could leak from. The most common spots are where the main case and tail meet or the rear seal or a top plate. On the tail seal where the yoke is that is a very simple fix. If you need a seal we have them for 6 dollars or so and you can get them from any shop that deals with tremec. You can use a small pry bar and pop it out and then I use a peice of aluminum thats the same size as my seal driver to put it back in. Give me a call if you need any help with it at 865-609-8187 ext 207
