Thread: Pedal Assembly
Old 11-30-2006, 07:17 AM
Automan Automan is offline
Default Pedal Assembly
Will heres another thread. I dont know what i would do without this forum. Well i cut out the areas above the driverside foot box as the scribe lines called for. I go and place my 87 ford mustang pedal assembly and find out that it is not even close. The clutch pedal rubs along the side so i have to make it wider. The whole assembly has so many holes that it will never pass safety. Also if i push it up all the way to the firewall, there is still a big gap for that i can't mount the booster mount. The whole cut out is just not right. I should of really spent alot more time on this before cutting it but oh well. I can always start covering up the open spaces with steel. Also i cut the clutch pedal as per the instructions and assembled it. The problem is as per the manual, the part where the clevis it suppose to mount from the clutch master cyling is facing up and not down. It is impossible for it to face down because the base of the pedal assembly doesn't allow it because it radiuses out. I can cut it away but is this the way to do it. I know that a few of my my fellow builders used the pedal system coming up from the floor but is there anyone that used the same system as per the assembly manual.
Thanks
automan
