Old 12-01-2006, 09:46 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally Posted by CobraV8
Mike you are right, it is a lakewood bellhousing. I recently had a starter problem and suspected the bellhousing alignment to be the cause, however it turned out the brand new starter itself was defective.
If the alignment was so far off to break the clips on the throwout bearing I think there would be some real problems with the transmission input shaft.
But you're right, you never know with these aftermarket bellhousings.
What about the clip on the clutch fork? Did Ford produce several styles of pivots and forks?
I am not sure if Ford made different versions of the clips. You have the same set-up I had on my 428FE and toploader. Is it possible the arm is over extending or pivoting incorrectly? My fork did not have the metal clip attached to it, but was the same shape and style as yours. I think you should contact http://www.4speedtoploaders.com/ and ask David. He would know about the fork and clips.
--Mike / Turn Ten Racing, Inc.
