Old 12-01-2006, 01:03 PM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I ran a similar setup in a '65 HiPo Mustang and the only problem I ever had was that pivot kept braking so a friend welded in a triangular support. No problem after that.
If your fork is going in too far and hitting those clips, there seems to be an alignment problem of some sort. If everything else works well and you have all of the correct parts, the holes in the pivot could be modified so that it could be moved outwards slightly or I guess you could grind an 1/8" off of the ends of the fork. However, I would start by checking the alignment and making sure that you have the correct fork and/or correct pivot for that bellhousing before modifying anything.
Wayne
Don't get caught dead, sitting on your seat belt.
