Old 12-01-2006, 08:27 PM
Tom Howland Tom Howland is offline
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
cdcofer, thanks for the kind words. My front clip was built to slide into the existing frame rails.
Just to the left of the oil pan is the new joint of the old level frame and the new angled frame.
I inverted this picture so you can see the frame in the correct position. The level pieces to the left slide into the old frame. The radiator sits between the wide level pieces to the right.
Arthur, I was never happy with the MGB suspension. The new suspension performs 100% better. Rat_rod_Russell has done a better job of fabing the a-arms to the frame. He put them at the correct front to rear angle where as mine are level. That angle would change the castor with wheel rise and fall. I don't know what difference that would make.
Tom
