12-03-2006, 04:15 PM
Il
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
2 terms that are often confused in some circles are Dual feed and double pumper. A double pumper is a mechanical secondary carb with 2 accelerator pumps, one for the primaries and one for the secondaries. That way when you kick open the secondaries there is no bog or pop back. A dual feed just means that there is and external fuel line to both bowls insead of a small tube leading from the front bowl to the back one. I don't know for sure which carb you have but I believe all Street Avengers are vacuum secondary and would not be a double pumper.
WDZ
