Old 12-03-2006, 07:10 PM
RodgerH RodgerH is offline
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Originally Posted by jwoodard
RogerH,
Just in case you're not clear on the reponses so far, in a SPF, there is not room to remove or install the headers with an FE or 460 engine installed. If you're doing your initial install, place the headers in the fender wells before dropping the engine in.
Steve,
Tim is correct. The SPF stock side pipes are rather restrictive, as are the Lone Star's.
I've owned both makes and modified the side pipes on both.
Thanks Jim.
That was what I initially thought, but I was hoping to learn otherwise. But, no joy. It will be an initial install. I agree with you on the restrictiveness of the stock SPF sidepipes. Definitely planning to do something different with them.
Rodger
