Old 12-04-2006, 05:27 AM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Thanks guys. The setup is a hydraulic with a master cylinder on the frame and a slave cylinder attached to the block that acuates the arm.
I did have the Lakewood aligned by Keith Craft when he rebuilt the motor. I think Bob may be on to something as I did put in a new tranny mount setup when I last re-installed the engine so it may be sitting a tad bit higher. Will also check on the cut-off of the fork. Still using the original fork that Phil Cool installed when he built it and had assumed he would have done that.
Also, it's a new throwout bearing that was installed about 200-300 miles ago. Any way to tell if it's good or bad without pulling the tranny? Also, RBLONG, no inspection covers on the Lakewood.
