Old 12-04-2006, 11:36 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
I used a stuck Comp Plus as the model to cut the hole and make the shift handle.
Once I did that, it was a matter of bolting the shifter in place and then setting the rods. If you have a torch, you can make your own rods.
The handle will need to be shifted about 3 inches to the right ( measure to make sure for yours ). There are two bolts on top, bolt the handle through the holes and you should be ready to go.
It was a good shifter for me. I had broken a Comp. Plus in London and got the Street Super as a replacement. I finally went to TKO600 later and am currently selling the whole shootin match to Roger.
Make sure you get a plate that is low enough or the shifter will hit the tunnel.
I think it will look great if that Aluminum is polished and clear coated. OR, you might want to think about having your name machine in the handle and knob ( or initials? ).
I powder coated the handle and used a Hurst T handle.
I can see 3/8 inch by 1.250 inch aluminum bar, bent 60 degree and a again 60 degees to put the handle up through a hole in the center. Then, you might want to tip it forward above the shift opening to put the knob forward for your hand placement ( did this and was nice for me ). Bevel 1/8 inch all edges and holes. Polished and clear coated. Turn the 3/8 bar to a 3/8 NC threaded end.
Yeah, that would be excellent.
