  #28 (permalink)
Old 12-04-2006, 04:41 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
That was why we spent many months re-enforcing the chassis to make it stronger..... All over the chassis.....
In addition we added a 1/4" plate of Aluminum the length of the chassis to tie everything together ..... flat bottom aero and strength....
Much like a book case in your home that doesn't have a back strap or panel on it.....it's very unstable and will flex easily...... until you add the back strap or panel..... then the book case stiffens up very quickly......
The weakest part of these cars is the passenger compartment anyway.... they want to fold in half........ so we spent many hours welding in new stainless steel to make the chassis strong...... with additional bars under the floor and in the door area's....... tieing the main hoop to the front cowl hoop and frame....
All of this fabricating worked out very well..... as we now have a chassis that is Stainless Steel.....same as mild steel....but doesn't oxidize.... and we clean it with Brake cleen........and is strong...... as shown on the first time it went out at the race track.... Run n Gun....
Morris
Morris
