Old 12-05-2006, 02:20 AM
TUF-427's Avatar
TUF-427 TUF-427 is offline
Cobra Make, Engine: Drb,5.6 8tb Windsor,TFS heads,Dart Shp,TKO600 ,4link 9in diff.Ford acid rush Paint,convopro wheels.
The pumps fitted to australian engines are unique to here, so the american pumps of either direction wont fit your timing cover.
You will need to do a 3 bolt timing cover swap as mentioned above if you want to run the older type pumps.
The aussie pumps are shorter than the american ones which may be an advantage in some kits
