Old 12-05-2006, 07:04 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
olddog
Your son was very lucky, indeed.
Xavier
A couple of points to remember when starting a new engine.
Check everything before attempting to even crank the engine. That includes the fuel line, gas pump, etc., all electrical connections, set the timing by eye so that it should be very close and make sure that you are not off by 180 degrees. Check the firing order, check the rotor. Prime the carburator and pump the throttle a couple of times while looking down through the carb to make sure that the accelerator pump is giving a squirt. Start the engine, immediately bring the revs up to 1500 to 2000 RPM, DO NOT LET A NEW ENGINE IDLE DURING THE FIRST 10 OR 15 MINUTES. Watch the gauges, especially oil pressure, check to see if the coolant is flowing. If the engine doesn't start with in a few seconds of cranking, stop and find out what is wrong. DO NOT CONTINUE TO CRANK A NEW ENGINE. Set the timing and continue to watch the oil pressure and temp. After running the engine for 10 or 15 minutes at 2000 RPM, let it slow down, begin to adjust the idle, etc. Always watch for anything that is not normal, for example glowing headers, smoke, over heating, back firing, etc. I'm sure that I have missed a few points but you get the idea.
A new engine must fire up right away, excessive cranking or allowing it to run at idle speed may eat the cam and/or lifters within the first few minutes. Good luck with your engine. Let us know how you make out.
Wayne
Don't get caught dead, sitting on your seat belt.
