Old 12-05-2006, 06:40 PM
decooney's Avatar
decooney decooney is offline
Scott,
Just curious, do you have Yellow Spax shocks on your ERA and how many clicks (or 1/4 turns) are they set at for the front and the rear? Are they IBOC springs, and what weight/lb are they? Also, did you lower the rear at all? I ran those same tires on my ERA and only had rubbing problems on full turns on the front only. It would also be good to find out if ERA narrowed those control arms on your car or if the original builder/owner did it themselves. The rear may be a tad different width than spec'd. As I recall my track from hub to hub in the rear is about 53.5" wide. DC
Duane
