Old 12-07-2006, 09:53 AM
Default Scott and ERA
Scott Are cars are cousins. ERA has a kit for putting bigger tires on your car. I run 335-35-17 pilots on 6 pin drive wheels. You will add these 2 fiberglass panels behind the seat to give your rear tires more room to move. You may want to look at a roll cage if you are going to push your car this hard. Ask Bob P to send you a picture of mine. The main hoop is taller, added the FIA bar going to the passenger side and a loop around the drivers side to the floor just under the door down to the floor. You can't see it from the outside, Niether the door or the body was cut to fit. A road racing seat would be another thing to add to the car. I believe that the springs and shocks are for street use. You need to go to 600lbs front and 500 lbs rear for track racing Camber, caster and toe need to be changed. You will need to get a larger sway bar for the rear also, 7/8" instead of 3/4". After this it is roadtesting at the track and tire temp work as Scotty J said. Rick Lake
