Thread: Leaking TKO600
Old 12-08-2006, 07:05 AM
Jimi G's Avatar
Jimi G Jimi G is offline
Put about a 1/4" bead around the surface that seals around the input hole in the case and around the outer rim. A little tip about the sealer is it will be easier to use if it is room temp. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
