Thread: Overflow tank
Old 12-08-2006, 05:03 PM
wizard's Avatar
wizard wizard is offline
Cobra Make, Engine: West Coast 460, Performer Cam & Intake, Edelbrock 750cfm Carb
Loose.
If it's tight pressure will build and prevent water from moving back and forth.
An alternative you might try is use a radiator cap rated at less pressure than your regular cap, the lower the better, but I would still be careful.
How is water routed to this tank? Normally , they are fed from the bottom so water moves back and forth and not air. ( am assuming you have a hose connected at the other end to the pressure bleed off port on the primary filler neck.)
Some pics would helpful.
"Nobody gets to see the Wizard. Not Nobody. Not Nohow.
