Thread: AN fittings
Old 12-12-2006, 08:23 AM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
You can see here ..... you mount the hose end to the hose...... then hose to the connector on one end.......and then put the hose in position where you want it to be......
Then install the Aeroquip hose end you are going to use ....and find the line mark on the hose end fitting ......that is where you mark your hose.....to cut.....
Morris
