Old 12-12-2006, 11:29 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
John,
Near the oil filter boss is a 1/4 NPT hole that you know is for oil gauge or a pressure sending unit. Just above that is a 3/8 x 18 hole for the clutch fork ball. You do not need to block this blind hole if not used.
Just above the oil pan rail in about the center of the length of the block on each side is a 1/4 NPT hole that enters into the coolant cavity. I place petcocks for draining block on each side, agian they are 1/4 pipe thread. On the head deck area to the rear of # 7 cyl is a 1/4 pipe thread hole you need to plug after plug inserted in oil galley and before head is installed. Many blocks also have another oil galley port on the back of the block near the bellhousing mount surface, not inside bellhousing or behind flywheel but on thin area of rear of block. This is to the rear of the distrib. mount location.
Hope this helps you. Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
