Thread: gasket
Old 12-17-2006, 09:24 PM
RedSnake351's Avatar
RedSnake351 RedSnake351 is offline
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by ebiggs1
In another life I was a "die maker". I had a hard time finding a gasket for the header to side pipe flange, so I made a die to cut them out. See pic in my gallery. I did find a set for $25 bucks but these only cost me $12.
I guess only time will tell whether they will stand up to the pressure and heat. I bought a set of the gaskets from Finishline about a year ago and tonight after disassembling the collector flange I noticed that those gaskets have started to break down again. I made sure I tightened the hell out of the bolts and nuts at the sealing joint, there was still evidence of the gasket going bad after about 1500 miles. I am thinking of contacting a gasket manufacturer and having them make them out of a fairly thick copper sheeting.
Any thoughts?
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
