Thread: sidepipe seal
Old 12-18-2006, 03:21 PM
Richard Hudgins's Avatar
Richard Hudgins Richard Hudgins is offline
Cobra Make, Engine: Porsche 928 S4
Originally Posted by COACH MIKE
Richard:
Let me get this straight. I can leave the pipes on the car and put axle grease on the top of the slip ins, start the car and let it run down into the fittings as the engine is running. Once the fitting stop smoking I cut the engine off. If my fitting are larger than your specs (.015) then I may have to perform this procedure more than once. This will seal the pipes?
Thanks, Coach Mike
Coach Mike,
You need to put the grease on before you slide them on.
If your pipes have too much clearance, they will not seal no matter what you put on them.
If your primaries are 1.75 Dia. then the proper clearance will be .0265 >.0300 in. With these clearances, you will not need a sealer just as rblong states.
Best regards,
Richard Hudgins
