Old 12-20-2006, 05:31 PM
madmaxx madmaxx is offline
A special custom frame which I had no luck in finding after going to 6 auto parts stores should not be required to mount an item as simple as a licence plate or the liscense plate frame should be supplied with the car. If you view my photos it is shown how I had to modify the frame. You risk damaging the paint when mounting the screws from behind, when drilling the holes in the license plate holder higher, and posibly damaging the the licensce plate lights wiring. I spent no less than 6 hours modifying mine with the assistance of a die grinder and air compressor. If I would not have had blue painter tape and duck tape protecting the trunk I would have had a huge scratch when the dremel tool slid off the screws as I was cutting the screws so the threads would not protrude past the nut so I could mount the decorative nut caps. I guess for $28,900 I feel this should not be an issue. Maybe you do have to spend an extra 13k on a Superformance for this one difference. Different things are worth different amounts to different people.
