Thread: Body Attachment
Old 12-21-2006, 09:58 AM
RogerM RogerM is offline
Cobra Make, Engine: Lone Star LS427, Jasper 395W
Funfer2-
The new adjustable a-arms mount about 1 inch below the old ones on the same flange. So, you just have to drill two new mounting holes about 1 inch below the old a-arm mounting holes.
To do that you will probably have to cut a little bit of the glass from the "t" shaped slot that you originally cut for the shock towers and a-arm mounts. Depending how you originally cut the slot you might not have much to cut at all and might just be able to grind or heavy sand the slot bigger.
