Old 12-21-2006, 08:36 PM
RodgerH RodgerH is offline
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Originally Posted by Power Surge
They will always cross at 5252. On graphs where that doesn't happen, it's because the scaling is different on the hp and toque axis', not because something is wrong with the dyno.
True. The graph's HP and torque curves must use the same scale for the crossing point to be an indicator of dyno accuracy.
If the graph's HP and torque scales are different, you'll have to determine the numeric values for HP and torque at 5252 from the graph, or get them from the spreadsheet. The numbers will be nearly the same if the dyno is accurate.
Rodger
