Old 12-26-2006, 07:31 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Here are the specs.
Lobe size bc/ht IN: 1.350 EX 1.350
Intake & Exhaust
Lobe Separation =111.9 Cam Deg
Valve overlap = 23.4
Intake
valve open = 14.6
centerline =
valve close = 50.2
Duration-----> 244.7
lobe lift 37689 IN
valve lift-----> .65956 IN
lobe area = 30.85 In * Deg
Exhaust
valve open = 60.5
Centerline 115.8 BTDC
valve close 8.9 ATDC
Duration------> 249.3
lobe lift .3789
valve lift -----> .66307
lobe area = 31.83 IN DEG
I hope this helps. I am not to familiar about cams. If there is more information needed please let me know. Thanks for you help
