Old 12-27-2006, 03:35 AM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
you don't need the alternator. Put a solenoid switch in. It is cheap and you don't have to get a big switch for the large amp draw. One battery is fine. ignition doesn't draw much to run the engine. I also bought a $8 ignition switch from the auto parts store. Makes it easy to wire up and a set of cheap mechanical gauges. I did wire my alt. to pretest my wiring for the charging system but you don't have to.
