Thread: Tranny Spacer
Old 12-27-2006, 10:45 AM
Default Gm Input Shaft .300" Too Long
Guys there is a foot note in the lakewood bell housing installment where the GM input on an FE motor is .300" too long. You can use a spacer, change the input shaft or get the input cut down in lenght to fit. I did the 3rd choice. If you don't do this you will wear out the thrust bearing on the crank. I am running a pilot bearing also. Make sure you center the bellhousing on the motor also. Rick Lake
