Thread: Fuel Pump Relay
Old 12-28-2006, 06:36 AM
bremillard bremillard is offline
Cobra Make, Engine: shell valley, all aluminum 540 ci chevy
Originally Posted by dvcobra
Is there a way to test the pump for an intermittent internal short? Yes, I have a return line
Thank you for your help.
First, check all of your wiring-the entire fuel pump circuit. Check the grounds as well. If all of the connections are tight and the grounds are good, barring an improbable run of bad relays, your problem has to be in the pump. It could have a bad bearing or wires causing excess current draw. Do you have a fuse in the circuit. If not, you should to prevent the kind of thing you are experiencing from happening. If the pump is causing the relays to burn up that quickly you probably have a safety issue that needs immediate address. -Bob
