Old 12-28-2006, 09:02 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
The 8.8 with the Ford rear disc setup is 1 1/2" wider than the older drum rear ends. They are setup for the antilock system. The 10" wheel that you have shouldn't stick out that far. With the 5" backspace and the wider rear they may stick out a little. The lower arms you have use the strut rod setup. The other arm is the strutless type and a frame modification is necessary to use them.
Don
