  #22 (permalink)
Old 12-30-2006, 08:53 AM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by kris-kincaid
If you get a used Jag diff for say $500, then get ENTDOC's source for rebuilding them at $400-$500, then buy Kirkhams $375 adaptor to mount it, you're at $1375 or so. Does Kirkham include the drive flanges to hook up Cobra half-shafts to the Jag diff in the $375? If not, add that on.
In the end you're saving $3500 or so on a $70,000+ car. Nice!
And it's not even that much savings. You still need to buy the axles and it has to all be installed in the car. The Kirkham's 5k rear end option gives you the entire rear assembly, installed and set up in the car. Plus it's an alloy housing, with all NEW parts.
So in reality, if you factor in using a used cast housing, used gears, and a used diff, as opposed to an alloy case, all new parts, factory installed in the car, what are you really saving?
Sal Mennella
