  #39 (permalink)
Old 12-31-2006, 09:51 AM
blykins blykins is offline
Put #1 cylinder to TDC of the compression stroke (make sure it's compression....pull a valve cover and look at the rocker arms if you have to). Pull the distributor out, point the rotor at the #1 spark plug wire and put the distributor back in. Start it up....use a timing light to time it by turning the distributor.
