Old 01-04-2007, 11:31 AM
427SnakeSC's Avatar
427SnakeSC 427SnakeSC is offline
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Originally Posted by RedCSX1
When I was assembling my CSX I ordered all the trans related parts through David Kee. He recommended the Steel flywheel to me over the aluminum. Granted the aluminum does give the car some zing however some people who had them installed where not super please with the end result.
Carb: I am running a 830cfm DP with annular discharge which is a good carb for my 482 Pond motor. Much better than the Mighty Demon I had on there before.
I have KC building me basically the same engine you have. I am using a cast Pond block with much of the same equip. Are you recommending I go with the steel flywheel? If so, why? I'll be going with a 482 bore & stroke. Edlebrock alluminum heads, mild HR cam.
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
