Thread: Horn Button
Old 01-05-2007, 10:47 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
My column has a connector protruding about halfway down. This connector has the horn circuit in it to allow use of the button. I've highlighted the connector in the picture. The black wire goes to the horn button and should be wired into the ground circuit for the horn relay.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
