Old 01-07-2007, 08:10 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by FFR428
I'd ask to knock out a freeze plug to verify it has 427 cyl wall cores inside and drill bit test it. Some 406's were cast with 427 wall cores tho. So anything is possible. My C3AE-D 406 block was cast with one set of 427 wall cores on one side... and 406 cores on the other. .
If that's the case, you should probably knock out a freeze plug on both sides to do the drill bit test.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
