Old 01-07-2007, 02:31 PM
Philm's Avatar
Philm Philm is offline
Default Bring back the carbs.
HI Richard,
That is not good to hear, I have a similar set up to you 347 and Motec.
I am not sure who you use but I know of 2 tuners that I have used that seam to know what they are doing, Scott from Insight at Arndel Park and Justin from JEM at Liverpool.
These problem may be due to the postion of the sensors, I am not sure of how it is set up but with my limited knowledge it sounds like you are not getting the correct air temp readings, if there is a problem it should be hard to start but it should start.
We did find a problem with advance /retard settings with the motec, the system would reset itself and go to a default setting making it impossible to start.
Phil
