Old 01-10-2007, 05:31 PM
jared1970 jared1970 is offline
I'm running factory adjustable arms on heavy duty shafts with the stud kit and the aluminum spacers and shaft supports from Precision Oil Pumps. I'm running .540/.565 lift on a hydraulic flat tappet cam, 320 lbs. open spring pressure, and hardened 7/16 pushrods. No problems whatsoever. I went with the adjustable rocker arms in case I wanted to switch to a solid lifter cam later, so I don't know how well the non-adjustable rocker arms work with the edelbrock heads. And take Anthony's advice and open up the pushrod tubes in the intake. I did a test fit with my intake and pushrods and everything in place, and had 3 pushrods rubbing on the intake. Opened up the pushrod tubes a little and all was well.
